I got a iphone se recently and it supports esim. Are there any low cost mvnos that use esim? I would love to not have to order physical sim cards if I can avoid it.
As I understand it, there are only a few carriers that support this with Visible being one of those ($25/month with party pay for unlimited everything). Keep in mind that data can be deprioritized quite a bit at times if you are in an area with little coverage or when there is heavily congested.
Prepaidcompare.net let's you filter for eSIM only MVNO's.
mint mobile
visible
tmobile connect/prepaid
ββββatt prepaid
googlefi
There are several data only esim providers as well. You can get a low cost talk/text plan from one provider and data from another one. I love Dent mobile as the data is good for 365 days.
Can anyone comment on how well eSIM works on Mint? I'm curious because the iPhone SE I just ordered from Xfinity will qualify for unlocking in just over 2 months, and Mint always has a really good deal during the holidays.
US Mobile are close to getting esim ready
Works well. The trial can be done on esim so you might want to try that first.
Also t-mobile test drive can be used on the esim so you can get a month free doing that every 6 months.
