Has anyone finally figured out the right APN for this SIM? I've got mine in an old Moto Z3, and pretty much get nothin'. Thanks in advance.
That's weird, pretty sure it auto-installed the APN on my Moto X4. There is a reddit post here:
Mine looks like that except the APN type just says default and port is blank, but it's been working fine for me so far.
I have 2 phones using the Walmart FreedomPop SIM. One auto-installed the APN, and the other got 4 push notifications and directed me to install them. The 2 APNs are different, and both are actually several APNs, with all enabled, but only the primary one 'selected'.
Device one: (Tracfone TCL LX, unlocked)
Name: SIMPLE_APN (selected)
APN simple
Authentication type: PAP
APN type: default
APN #2
Name SIMPLE_MMS
APN: simple
APN type: mms
APN #3
Application Access Point
APN: wholesale
APN type: default
APN #4
APN wholesale
APN type: mms
The second phone, a Moto E5, auto-installed these 2 APNs
| Main APN | |
| Name | Access Point_1 |
| APN | wholesale |
| MCC | 310 |
| MNC | 240 |
| Authentication type | PAP |
| APN Protocol | IPv4 |
| APN roaming protocol | IPv4 |
| APN enabled | enabled |
| MVNO type | None |
|2nd APN/MMS|not checked, but installed|
|Name|Plintron MMS|
|APN |wholesale|
|MMSC| http://wholesale.mmsmvno.com/mms/wapenc|
|MMS Proxy|not set|
|MMS port|not set|
|MCC|310|
|MNC|240|
|Authentication type|PAP|
|APN type|mms|
|APN protocol|IPv4|
|APN roaming protocol|IPv4|
|APN enable|enabled|
|MVNO type|None|
(Sorry for the odd formatting-- copied from a spreadsheet.)
Thanks...I'll try these out.
If the APN in drysun's link works out for you, it seems easier to configure (as a single APN.)
I'm using my only SIM on my daughter's kids smartwatch. I think the APN auto-populated with several different options. I selected the one with 'epc.tmobile.com' and it works fine.
APN epc.tmobile.com is what works for me.
