Typically the case costs me as much as the phone. Because my phones are cheap and the cases are military grade. So my typical phone will be a $100 phone that I bought for $30 and the case will also be costing about $30. The phones of course are valuable to me because of what I load on it, how much time I put into downloading apps, etc etc. But is it really worth spending so much on a case? What do you guys use for cases, what brands do you buy and how much do you spend on a case typically?
I always use a case because it helps to prevent the phone from sliding out of my pocket and my hand and offers some protection should I ever drop it. Like, Chelle, I prefer to get mine from Amazon (easy to return) or from China. I prefer one piece and rugged.
I bought an OtterBox, which happened to be on sale at a good price, simply because it seemed likely that I would drop the phone at some point. It cost around $25.
It has proved its worth twice so far.
Apart from the cost, the real negative is that it is a nightmare to switch sims.
We have extremely tight fitting Speck military grade cases on the iPhone 6S+.
I took a very sharp hobby knife and cut out a hole to allow access to the sim tray.
I also purchased clear credit card protectors from ebay and can hold multiple sims and an eject tool on a piece of card which then goes into my wallet. It came in handy for our recent trip to the UK, firstly swapping in the Global Sim while on the way there and then putting the LTE sim back in on the way back.
Ebay has pre made credit card sized sim holders as well as slim hard storage cases, similar to business card holders, for multiple sims.
I just checked the case for my phone and it looks like there is a joint/raised knob right where the sim tray is located. So I would be a bit nervous about attempting to modify it as the whole side might just break.
Honestly it is hard to see why the tray is not accessible. Perhaps it was just a design oversight.
A tech at the Apple Store manged to take the case apart with his bare hands with some effort--very impressive dexterity.
It is a three piece assembly and the two that form the inner box are indeed hard to take apart.
You are right that the instructions do make the process seem simple and there a several You Tube videos for people like me who seem to still find it a challenge. Between these two resources, I have manged to get it done a few times.
Of course, the problem could be me rather than case itself.
A number of people have mentioned that I have Idiopathic Digital Intricate Operation Tactility syndrome, usually described as being an "IDIOT."
I do not know whether OtterBox outperforms other rugged cases. At the time I was looking for a case, its model was on sale and seemed like a "good deal" in relative terms.
