So it seems that the pending on the carrier that you use is how Nomorobo works.
FiOS:. When a telemarketer calls you will see the number or name on the TV or phone but no ring. This is great because even one ring can wake you.
Time Warner:. You get one ring and it shows on the television who is calling what stops it from further ring. the problem is the constant one ring is very annoying and can wake you.
The nomorobo website states that you must have a ring. For various reasons. But how come that's not the case on FiOS?
Any suggestions on how to stop the one ring on any carrier?
Would getting an actual physical box too attached to your phone that blocks calls solve this issue?
I'm not sure why Nomorobo would work differently with Verizon Fios. If the corded/cordless phone is displaying caller ID for the blocked calls, perhaps the ringer is delayed.
