No calls working for me and can't login to site.They are aware of the problem and are working on it. No estimate of when it will be fixed, I'm sure they are swamped.
We can confirm our service issues are now resolved. Special characters/emojis may still be missing, and we will post a further update to when those are fully functioning again!
3:27 PM · Feb 3, 2020·Twitter for Android
Is it possible for a service shutdown to drain a phone's battery? If yes, then maybe TextNow had a service outage last night too -- my TextNow phone had a 70% charge last evening but was only 2% this morning (after a night of non-use).
A phone will use more battery if it's searching for a tower connection, or has a weak connection.
(My SO works in a facility where phones are required to be stored in metal lockers. Her phone would frequently exhaust the battery by the end of her shift until she started putting it in airplane mode.)
There have also been anecdotal reports of VoIP apps (notably FreedomPop) depleting battery faster than normal, perhaps if they keep reconnecting to the servers to report their presence to make incoming calls possible. This would likely be true of any other app that 'checks in' for updates and sync, as well.
oh yes, airplane mode! I forgot that! thanks for the reminder KentE!
I'll try that on the xp5. see, even though my old kyocera duraxts have 1360 mAh batteries they go ~1 month on standby before they need a charge. and they have a couple daily alarms. but the sonim xp5 even though it has a 3180 mAh battery it only lasts ~1 week on standby. no alarms on the xp5. I hardly use any of my mobile phones.
