This may have been answered elsewhere but I didn't find it. I have an old AT&T Pantech Matrix C740 3G phone that I decided to try the FreeUP SIM in. It knows the SIM is there and displays the associated phone # in Settings/Phone information, but service does not work. I added an APN with no better results. The APN fields available do not include all the fields in the specification, not sure if that is the problem, or something to do with it being a 3G phone, or... ? Anyone know?
[/quote]
Did you log into your account and associate your phone with the SIM?
[/quote]
Good question - forgot to mention that yes I did after it initially didn't work, and still having same issue.
You want to check it again, for I'm a bit leery of the statement below about not having to check your phone before signing up, although it does say if a phone doesn't work it can always be set up later. Perhaps an email or call to FreeUP is in order.
"WANT TO HANDLE THIS LATER?
Do you have a phone that you know will work with our network but don’t have it with you or don’t have time to check compatibility? No problem! You can simply move on to choosing your plan and we can link up your device later."
Inbound does go to voicemail, no outbound possible "No Service".
Thanks for the video, going to hold off on that for the time being.
FU support responded to my email very promptly (that was great news!) and suggested I try airplane mode on/off - no help. It may still be that the phone is incompatible, running the IMEI through the checker now did fail. I've given further info to Support and waiting to hear back.
Good luck with that. I emailed them over a month ago about missing credits and got a short reply asking for further info and that they would get back to me. I sent it and a month later I have heard nothing. I sent an email or two to chase them in between but no response.
I have contacted FU through the support link. KentE provided the CS phone number in the as stated below. The number and link may be the real ones.
"For additional FreeUP Mobile help, you may also call us at (888) 316-0686 to speak directly with a Customer Care Representative. FreeUP Mobile customers may dial 611 from their FreeUP Mobile device, and both calls are free. "
Just a thought....the only time I've reached out to Support was in the early days. In their email response was a (nearly invisible) link to log in to the Help Ticket site, and I needed to create a login to do so. (I created it with login credentials matching my sign-up info.) In the original reply I got from FreeUp, the access to the Ticket site only appeared when I hovered over the email header in my Inbox view. ("View Ticket" would appear.) https://freeupmobile.zendesk.com/hc/en-us
In my case, the Zendesk ticket exactly mirrored the chain of email exchanges. It did seem it might be beneficial to continue a conversation by replying to the original email (per the instructions in that email) rather than starting over with a new email support request.
That said, it seems that FreeUp has been pretty good with responding to questions about cellular service itself, and in explanations about how the Rewards system is intended to work-- but not good in following up about issues with the Rewards system not functioning correctly.
I tried to Google search a little about this, and found several reports of similar issues with the C740 and other Pantechs (eg, Pantech Duo) from the same era, but didn't spot a solution..
I suspect it's an APN issue, based on your info that some fields are not visible. What fields are missing? (Not sure that would mean much to me, but it might to someone with more knowledge of APN settings.....)
Barring other suggestions from Support or elsewhere, the Reset option might be worth trying before giving up entirely. Perhaps the missing fields would auto-populate with the correct info. A similar problem existed with some Sprint-network prepaid phones from that period, with some APN settings that simply could not be changed.
Thank you for the research. Support hasn't given me any definitive answer - they see the device as compatible according to their checker but were suggesting I try to locate info on the bands supported, etc. to confirm. I still need to research that. Also they gave the usual, try the SIM in another phone to make sure it still works, etc.
About the APN (called Profile on this phone) the fields are Connection Name, APN, Primary DNS, Secondary DNS, Linger Time, Authentication, Username, and Password - that's about it.
In the meantime, I tried the master reset, no joy. I'll report back if I find out anything more.
