It includes a GSM sim and a CDMA sim
can I use both of them?
Use the CDMA sim and my CDMA phone and the GSM in my gsm phone?
So would have AT& T in one and Verizon in the other?
Or would I have to pay double for that?
realLexusl21: did you have occasion to move away from the Verizon SIM, and then try to move back to it?
Most MVNOs will not allow reuse of AT&T or T-Mobile SIMs, but at least some will allow reuse of a Verizon SIM.
My experience with this is limited, but Tracfone groups gladly allow it with Verizon SIMs. Whether or not the mother carrier allows it, there's no guarantee that an MVNO will do so.
I noticed on the eBay $30 one year Red Pocket "CDMA" plan there is an option to select a GSM sim card, and I was under the impression that this plan was CDMA only in the past. If so, the ability to now use GSM T- Mobile is a plus for this very cheap plan.
