"Zoom recommends an internet speed of 1.5 megabits per second (mbps). If you plan to use Zoom at home, you can test your internet speed by going to http://www.speedtest.net/."
Chelle said TMOBILE 3g is just 512kbps. So just 1/2 a Meg
So that would not work.
No way to just turn off 4g lte on phone to get just 3g. I looked and the 3 settings does not include 3g alone. So no way to speed test just the 3g. Without using all the data in the plan
Thanks for the zoom info
Does your information tell you how much data Zoom uses per hour? This information will help us figure out if we need to buy the $15 6 gig add-on.
I think zoom uses somewhere between 1gb-2.5gb an hour. It depends on how many is on the call, video quality etc. You might want to disable HD if you are limited with data.
Yes 3g data ia not going to work well. You might be okay on the lowest settings but if this is for work you may have a lot of disruptions. Or it might shrink the screen to manage on lower bandwidth? I've never used zoom so not sure how it handles low bandwidth exactly. It should work fine for audio only.
Your 1 to 2.5 gig per hour usage seems higher then the 1.5 meg per second speed conversion.
Now finding a conversion calc on internet
1.5 meg per second equals .68 gig
2 gig of data equals almost 3 hours of zoom
6 gig of data equals 8.8 hours of zoom
10 gig of data from your hotspot you suggested is just 14 hours
There is no way of knowing if a zoom call would be an hour or all day.
You would think cable company's. Know people working from home during covid pandemic
Can a non host of a zoom call change the HD settings?
