So I need to buy a high-capacity USB drive, at least 1TB, ideally with a larger capacity. My objective is to encrypt it and carry it with me everywhere. I was thinking of a USB drive, but the read-write speeds on a flash drive may mean it takes forever to write 1TB of data. So I'm also open to any other thingie with at least 1TB capacity - that I can carry around with me everywhere. Something smaller than a portable hard drive would be good.
Any recommendations, suggestions? Please also chime in with brands I should stay away from, any other helpful tips, etc. Thank you much!
"Q: What are the USB data transfer rates and specifications?
USB 1.0/Low-Speed: 1.5 Megabits per second (Mbps)
USB 1.1/Full-Speed: 12 Mbps.
USB 2.0/Hi-Speed: 480 Mbps.
USB 3.0/SuperSpeed: 5 Gbps.
USB 3.1/SuperSpeed: 10 Gbps."
If you can afford it, go for a USB3 solution with the drive being SSD. I run a full Windows 10 OS from on such drive. Using a regular HD, the same setup is painfully slow, so certainly very different. Now, if you are working with very large files and random access is not a priority, you can get away with a regular HD.
P.S. Just sharing my experience. Be sure to research accordingly for the intended use
