Please reply to just the numbered questions
1). Is it ALL 15 silver ads for you or just one type.
- Are any 15 silver ads working for you. If so which ones
3). Cellnuvo app version you using.
4). Android version are you using.
This info will help them fix this issue. They are working on it.
