Any suggestion for a LTE(GSM) hotspot with the following features?
- AT&T or unlocked
- runs on usb power without battery installed (would like to connect to car 12 volt power but don't want battery installed)
- quick boot up
This is probably not helpful as it is hard to find but if you can find one a Huawei E8372h-511 looks good - It has ATT LTE bands and is a usb mifi stick so you can plug it straight into a car charger. There is no battery.
They call it a wingle for some reason. A wireless or wifi dongle I guess.
I have never used this store but they have it listed here for reference. Make sure you get the 511 model for the right bands
Does any AT&T hotspots run without battery?
How about the 2372? Looks pretty old that it might run without battery.
Or AT&T Elevate 754S? Also seems old enough to maybe not check for battery.
I would be interested in knowing what you find.
Anyone brave enough?
2372 is 3g.
Oh, might have to surgically remove the cells from the battery pack while retaining the connector/circuitry.
