So I dont know if something like this exists, but never hurts to ask...
My current setup currently has: (Hangouts #) + (TruPhone) + (FreedomPop GSM Sim)
Because I am a strong believer in never throwing valuable things away, I was hoping it was possible to use a dual sim in order to connect to both FreedomPop for their data as well as TruPhone for their free incoming rates.
However, when I tried using my set-up with a N9100 (Dual Sim Note4) both sims were unrecognizable in sim slot 2, but fine in slot 1.
My best guess for the problem is as follows:
FreedomPop and Truphone use ATT exclusively
ATT cut their 2G tech beginning 2017
Sim 2 of N9100 only supports 2G
TLDR:
Looking for truphone and freedompop on same phone.
Do dual sim phones exist allowing 3G and up on both sim slots?
*** I do not believe simultaneous use is necessary for calling on one and data on the other, however I could be wrong.
Is your freedompop sim the global sim or the att LTE one? The global one should be recognized in the sim 2 as it can do 2g data. It roams on att and tmobile. The dual sim note 4 has no USA lte bands.
I will definitely check that out, and its weird because my freedompop sim is the global gsm. Maybe the used phone I got just has a broken sim 2 slot, but its hard to imagine because when I put the sims in there it does pickup emergency calls only...
I tried this and forced my Freedompop Global sim on 2G and it does connect to T-Mobile. My phone has LTE bands but not for US AT&T or T-Mobile. Mine is a Meizu M2 Note.
My personal decision was to just play the waiting game to get a better phone at a lower price, so no freedompop sim data for now. Preferable phone would have FreedomPop Global Sim as Sim 1 with the fastest speeds and Truphone as Sim 2 with good connection to phone calls on working ATT technology.
TruPhone uses AT&T, which no longer supports 2g which is required on one SIM slot. You may wish to consider Toggle Mobile instead of TruPhone, as Toggle uses T-Mobile, which does have 2g voice.
A decent choice. I'd probably go with the v20 over the g5. The reports of the g5 h860n being dual 3g/4g at the same time on both slots didn't seem very concrete. I've had the non n version and it was 2g on slot 2. Seems unlikely to be different for the n version.
Wide angle cameras are fun. And coming from a note you'll like the size better vs the g5.
I actually almost made the mistake of getting the V20 N instead of the V20 DS. People have stated that the DS does have the 3G on both slots. When I physically get the phone I will personally confirm it here, in case if that helps anyone else.
How is the size of it? I thought about a V20 but the size put me off. I've used a note 5 before and it was okay but note sure I want to go with the even larger v20. Is the second screen useful?
Coming from a note 4, I like the size because other phones to me were to small or too slow. I wish I could compare it to the note 5, but when Samsung started taking away the removable battery and SD card they pretty much lost me as a loyal customer. You could say it "blew up" in their face. I actually really like the second screen because its basically an extremely detailed notification light, which also hardly touches the battery. However, if one doesn't like that feature, it is disable-able. A few things I will mention that were a little disappointing to me, but not necessarily a deal breaker were:
While the phones type-c cord does provide extremely impressive charge times, it also means all my other android cords are obsolete.
No physical front buttons like the note series home button. Also since my phone is in an Otterbox case with the belt clip, I would need to "unclip" the phone every-time to turn it off. Both of those will just take some getting use too.
Finally understanding "stand-by" dual sim phones pretty much make them a Verizon/Sprint phone (no simultaneous calling/data on the separate sims)
Other than those extremely small nit picky things, I would absolutely recommend this phone (even with the expensive price tag).
Any other questions about the phone, I would be happy to answer.
